wa8yxm
Aug 25, 2016Explorer III
If those outlets are "Related". the most likely cause is a screw loose.
Many Rvers have a few screws loose. like the ones that hold the wires in the power distribution center.
Another cause is space heaters.. The outlets in RV's are ****, heavy loads (Space heaters are about 12 amps) tend to draw enough current that the wires overheat where they connect to the punch down connectors inside the quick box outlet.. Replacement with a proper outlet and box is the solution here.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
