SJ-Chris
May 19, 2021Explorer II
30sweeds wrote:
One of the belt idler or tensioner pulleys going bad.If that is the case,it's cheap and easy enough to fix but complete failure will leave you stranded.
When these start to fail (idler or tensioner), does it make sense that the sound happens from a cold start and goes away in 2-3 minutes? Maybe the bearings are starting to go and once they start rotating via the belt they quickly heat up and it makes the whirling sound go away????
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
