dougrainer
Jul 06, 2016Nomad
If you had a Freon/410 leak bad enough for you to smell it inside, it would then NOT cool. You state it has cooled correctly for a few days. They only hold 1 lb. of coolant, and if a leak bad enough to smell inside, it would not have enough coolant to continue cooling. Something else is causing that smell. Check the upper unit condenser and evap for foreign debris. Doug
