joe0508's avatar
joe0508
stripped nut
I have a battery post that i cant loosen or tighten.It is loose and i cant tighten it down.Does anyone have any suggestions on what i need to do to get the bolt off?
  • jwmII wrote:
    Those terminals are dirt cheap. Cut the bolt and free up your wiring and install a new terminal on the post and the wiring on the bolt for that purpose. Buy an extra to keep in your parts box. This'll probably come up again.
    Thanks for the reply.Maybe i can catch a thread by prying up on the nut.I havent tryed that yet.If that dont work i will cut the nut with a tool.
  • smkettner wrote:
    Can you put another nut on it and extend the post?
    Otherwise a nut splitter is the tool you need.
    It already has 2 nuts on it but to answer your question i can get another nut on it.
  • Would a 1/2-Inch across flat splitting tool work on a battery terminal?
  • PLEASE! DO NOT PRY ON THE BATTERY POST!
    Either around in a circle or straight up. New batteries are made differently. Think about it
    How do you suppose they get an RV terminal to stick up through the lid?
    TWO PIECES
    The same holds true for car battery conical posts.
    If you are careful, use a hacksaw to cut vertically down next to the post. This is a safe way.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
