MarshaNichols's avatar
Jun 21, 2013
stubborn alarm
2012 RT 170...had my propane/CO alarm go off...dealer said they couldn't find the problem...went off again and pulled the fuse and turned off the propane. I am taking it back for the service tech. to get to the bottom of it. Has this happened to anyone out there? Suggestions? :h
  • Everything from air freshner to onion peels in the trash can will set these things off.
  • hershey wrote:
    Propane detectors are throwaway items. Many items used (hair spray) will cause them to fault. Once they start faulting, you just bite the bullet and replace. Of course before the propane police jump on me, insure that there really isn't a propane leak.
    X2 many things can set them off
  • Propane detectors are throwaway items. Many items used (hair spray) will cause them to fault. Once they start faulting, you just bite the bullet and replace. Of course before the propane police jump on me, insure that there really isn't a propane leak.
  • Take it to a propane dealer and determine whether you have a propane leak - if no leak - then replace the detector. Pretty much what the "dealer" should have done.
  • Not sure when yours is going off, but I had a problem with batteries overcharging and gasses released would make alarm go off. I plug in at home which is where I store our MH and disconnect battery to be sure they do not overcharge.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 07, 2026
