rhagfo
Feb 02, 2017Explorer III
MrWizard wrote:
Got going
Found some info, A post on a fleet bus website, engine speed to high, would not engage,
Stuck throttle,
With everything off I reached down and pulled up on the pedal
Then did not touch pedal while turning the key
Was able to goto drive and moved RV
We are safely parked for the night
Hope everything is ok in the morning
Will be lubeing everything tomorrow staring at pedal linkage
Why no error code for this ?
I never touch the throttle while starting, engines are electronically controlled, no need to touch.
I would be checking throttle return spring, and APPS/TPS (AKA as the electronic device that controls engine speed).
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
