lynndiwagon
Feb 02, 2017Explorer
The Allison Transmission is mechanically practically bullet proof. I had a similar situation, with some really weird symptoms, and it ended up being the Transmission Control Module (TCM.) GM will charge about $900.00 to change this out. If you look around, on a national on line retailer (starts with the letter "A"), you can find this part for around $285.00 whereas GM will charge $700.00 for the same part. It will need to be programmed by the dealer. Might be worth having a spare one around as these are known to cause similar problems.
Here
Here
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
