stew47's avatar
stew47
Stuck slide
It’s on now. Here’s the story. I have a 2010 crossroads cruiser cf32bl. We go to camp site in rose point pa. Middle slide was stuck closed. Motor wouldn’t open it. So I used fifth wheel crank took ( first had to drill hole in side of camper) then gave half a crank and then it spun easy and used motor to open rest of way. So question is why did it hang up! Next question. What would I do if it was our bedroom slide on front of fifth wheel? There’s no way to crank it?
1 Reply
  • I found the motor for the bedroom slide on my 5th wheel under the bed. I had an access panel with 4 screws on the storage area floor. There's enough access to put the crank handle on the motor to operate it manually if necessary.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
