Almot
May 25, 2016Explorer III
Naio wrote:
Should I avoid PWM, is it a dead technology?
It's not dead, but the choice PWM vs MPPT will become clear once you've decided on total panel wattage.
If I get MPPT, does it not matter AT ALL what voltage a panel is?
No, but total Voc of array shouldn't exceed maximum input voltage that controller is rated to.
E.g., could I use a -40watt residential panel? Would that have other drawbacks? Wire size? Sturdiness?
40W is a maintainer and hardly needs any controller. Decide on TOTAL wattage. Your energy needs listed in the 1st post should be quantified with a proper energy audit. Without numbers of AH usage you won't get accurate estimate of needed solar wattage. Might as well toss a coin
Are his 145aH Dekas ok?
Battery bank depends on solar wattage and energy needs. Energy audit first.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
