SCVJeff
May 27, 2016Explorer
Almot wrote:Worse..SCVJeff wrote:
You KNOW what happened last time I tried picking those up. Slowly getting better tho..
I don't but can imagine, and 99% positive that you've only had one of two bad things happen, so far. Either back problem or hernia. Had both, on different occasions. In airports they mark "overweight luggage" anything over 50 lbs, for a good reason. 100-110 AH @ 63-66 lbs is absolute maximum I would want to deal with, on my own.
H1N1 Flu along with pneumonia that apparently DID kill me: 3 times they say. Woke up 3+ weeks later 50lb lighter, unable to walk, total 60 days in the hospital...that was thanksgiving. Once walking again and still at 132lb I, like an idiot decided to service the batteries which requires removal (must have been the drugs). Fortunately Niner called checking up on me, I told him what a dumb thing I did, and he was there within 30 mins. Thanks again Randy !! These are T-145 @72lb that, at the time I couldn't come close to lifting. I remove them out once a year to make sure the watering system is doing its job and the cells are balanced, and they have to come out for that.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
