Naio
Jun 03, 2016Explorer II
You want numbers? I got numbers.
I left the bank and came home sweet campsite to my killawatt meter.
Current freezer, the one mfr says is 1.8amps / 65watts is really 1 amp, 69 watts, on 117v AC according to the meter.
That's still not the 117 watts that it seems to me 1 amp should be, but at least it is closer.
Almot's $800 freezer in the link above is also 1 amp, 75 watt, and much larger. I'm gonna hazard my guess that the $50 craigslist freezer, currently 1500 miles away, is 3 amps and 210 watts. Yes, I pulled that number out of my azz.
So, calculating two ways, cribbing from Mr Tuna, above:
280 watts = 28 amp-hours. (allowing for inverter inefficiency).
28 ah x 12 h = 336 amp-hours.
xxxxxx
4 amps @ 117 volts = 468 watts
468 watts = 47 amp-hours
47ah x 12h = 574 amp-hours
So, somewhere between 300-600 amp-hours.
4 x 135aH batteries = 540AH, 50% is 270, so I might really get 5-10 hours of freezer time.
6 x x135aH x 50% = 400aH, 8-14 hours freezers.
I rounded off on the hours bec it is all so unclear anyway.
Why are the watts and amps not matching up?
xxxxxx
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
