pianotuna
Jun 03, 2016Nomad III
The accuracy of the Kill-a-watt on the amps setting, is not nearly as correct as the watts.
I just checked mine with an 11 watt fan @ 114 volts. The amp reading was 0.19 so that tells the tale.
Naio wrote:
You want numbers? I got numbers.
I left the bank and came home sweet campsite to my killawatt meter.
Current freezer, the one mfr says is 1.8amps / 65watts is really 1 amp, 69 watts, on 117v AC according to the meter.
That's still not the 117 watts that it seems to me 1 amp should be, but at least it is closer.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
