pianotuna
Jun 04, 2016Nomad III
Hi Naio,
Your boost voltage on the jars you purchased is between 14.1 and 14.4. Float you already know.
Temperature compensation on the jars you purchased is higher than most at 15 millivolts per degree C or 8.3 mv per degree F.
I.E. above 25 C (77 f) you do not want to be doing 14.4 volts into them.
Go with what the maker specifies, not with the (excellent) manual from lifeline.
