MrWizard
Jun 04, 2016Moderator
Alternator usually tapers the Volts down as temp goes up,
To protect the alternator
Nobody here is likely to be over charging four of these 102# agms
70 amps divided by (4) batteries = 17.5 amps per battery
Even a 100 amp wfco would only be 25 amps per battery
To get worried you would need a 400 amp charger
Stop and do the math!!
