Terryallan
Jan 01, 2018Explorer II
westend wrote:
To answer a few questions:
Ford's implementation of "door ajar" and what it does/doesn't do. This is all about the truck in my sig line, 2003 Ford F-250 Crew Cab 4x4 5.4 V8. When a door is left open or closed/unlatched, open/latched the door ajar circuit is powered, a signal voltage is sent to the instrument cluster illuminating the located open door and the trucks ECU keeps the circuit powering the cabin overhead light powered for about 10 minutes or until 1/4 mi of forward travel has occurred. When I first brought the truck home, a mechanically disinclined ex-buddy monkeyed around with a rear door child safety switch and the door ajar problem has persisted, since. The result is that the cabin overhead light remains on when parked or, sometimes comes on by itself for a short time. I guess it is time to do some surgery and repair/replace the offending mechanism. At the same time, I'll replace the cabin lights with LED's.
From what I am reading. It is NOT Fords system so much, as it is your buddy messing with the circuits.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
