Old-Biscuit
May 22, 2013Explorer III
Checked CB and 'appears' good......
Should use a voltmeter.
Test that you have 110V AC power thru CB to ON/OFF switch.
Test that you have 110V AC power from switch to the electric element
Check that the 110V High temp t-stat is reset (Push to reset...under rubber cover)
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
