ford_truck_guy
May 23, 2013Nomad
I just went threw the same exact issue... Circut breaker tested good with voltage after...on/off switch inside trailer tested good with voltage after...no voltage at element :h after messing around for a bit , i was moving the small on/off switch inside the heater compartment outside the trailer , went back to see the element and got shocked!!! It is all working now... The switch outside was on.. but not allowing electric to pass by...
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
