h2guy
May 23, 2013Explorer
flrp wrote:
I did a trial run about two weeks ago taking the RV out to make sure everything works before leaving on an extended trip. Everything worked as expected. Now I am out on a trip and the electric function of the Suburban 10 gallon water heater won't work. The propane works just fine. As to the electric option I have checked the circuit breaker in the electrical panel and it appears to be good. Does anyone have any suggestions?
Thanks
As Fordtruckguy points out, are you aware of the "second" switch mounted outside on the end of your WH?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
