dalenoel
Jan 05, 2015Explorer II
If you have never had to light the pilot before then it is electronic ignition. Can you hear the clicking of the electronic ignition? If not then it is not getting a signal from the thermostat or not acting on that signal. If it is clicking then it is a problem in the ignition. If you can see the spark then it is a fuel problem. May be no fuel or may be a valve not opening and getting a signal.
Is the fan coming on prior to the ignition sequence? If not then the purge sequence is not happening and that will stop ignition.
Think through the steps that need to happen, what you have heard in the past, and see where the steps stop and start looking from that point on.
