dougrainer
Feb 04, 2018Nomad
ALL the sail switch does is close to allow 12 volt positive thru it. You test the sail switch by just seeing if when running you have 12 volts on both wires at the sail switch. IF NOT, and you have 12 volts on one side and not the other the switch is bad. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
