- path1ExplorerThank you.
- Old-BiscuitExplorer IIISuburban uses a 3/4" NPT T&P Relief Vlave
Some water heaters have check valve in cold inlet AND hot outlet
Some have cold inlet
Some have hot outlet
Some NONE
80%......yours has one in HOT outlet - path1Explorer
DutchmenSport wrote:
I've never actually compared them, but I feel pretty certain the pressure relief valve is threaded the same. Check the valves though, I do think they come in different temperature settings, at least, they use to.
If you have a single valve water heater by-pass on your water heater, then yes, you do have a check valve on the hot out side.
If you have a 2 valve water heater by-pass, you might have a check valve on the hot out side.
If you have a 3 valve water heater by-pass, you probably do not have any check valves.
Thanks...I don't know how many by-pass valves I'll have to check. - DutchmenSportExplorerI've never actually compared them, but I feel pretty certain the pressure relief valve is threaded the same. Check the valves though, I do think they come in different temperature settings, at least, they use to.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
