Hemi_Joel's avatar
Hemi_Joel
Suburban LP water heater malfunction, need help.
Hi, I am on a road trip with my 2018 Eagle Cap 1165, and the water heater has malfunctioned. I hope someone can help me with info to get it running. It is a Suburban SW6D, SN 171504878. LP only, no 110v. Last night I noticed that it lit and shut off about 3 times, then stayed unlit. The fault light next to the switch remains lit when ever the switch is on. This morning, I turned off the switch inside the camper for a while, then when I turned it back on, I could hear the gas valve solenoid open and close 3 times, but no flame. I went outside and opened the cover of the water heater, and pressed the reset button, but could not feel any movement of the button. (under a rubber cover) Then I turned off the switch inside the camper to reset the start up cycle, and when I turned it back on, I ran outside to observe. The gas valve was opening, but no spark to light it. The next time the gas valve opened, I lit it with a lighter, and it fired, but only for a couple seconds and then the gas valve shut. I repeated this process a couple times, with the same results.
The batteries are fully charged, and there is 1-1/4 bottles of propane. The furnace and the stove both operate properly, proving a proper gas supply. I hate having to go to a dealer for repairs, especially on a road trip with a schedule. I have tools, a digital multi meter, and good mechanical/electrical skills. But it would be good to hear from the voice of experience before I go any further.
Thanks,
Joel
  • Gas valve operating would indicate that there is power to the circuit board.
    Have helper turn on water heater while you are at the unit. Listen for ignitor to spark.
    You could have a helper turn on water heater while you use a long lighter to ignite gas inside burner area. Becareful as it could flash back!
    Check the ignitor for proper spacing. Disconnect the ignitor wire, test it for conituity.
    Check the porcelain on the ignitor for cracks.
    Call Suburban for local repair person or shop. It could be bad circuit board. Could be still under warranty!
  • I just removed the cover from the thermostat and check it with the VOM. 12.6 volts on both terminals, confirming that it is functioning and calling for heat.
