truthsmiles
Mar 04, 2019Explorer
Suburban SW10PE - pilot works, but main burner won't light
Hi all - first time poster. Just bought a very neglected RV (brand unknown - even DMV couldn't figure it out from the VIN - but that's a question for another day!)
As the title implies, my RV has the SW10PE water heater - it's the kind with a manual pilot light (no electric ignitor) and a separate AC electric element.
The gas valve is a SIT-610-AC3. Here are some images stolen from amazon - pictured is exactly what I have...
Front:
Back (you can see the thermostat probe here):
The symptoms are that I'm able to light the pilot and turn the valve to "ON", and the pilot stays lit. So, I know the thermocouple is working and the gas valve is at least partially functional.
However, no matter where I set the temperature the main jet doesn't light. I've yet to disassemble and clean it (I know spiders like those tiny holes), but the soap bubble test shows nothing at all coming out.
So, at this point I suspect it may be the thermostat that's faulty. To be sure, the condition of the tank may be REALLY bad. The sacrificial anode is completely gone and the electric element is open, so it wouldn't shock me if the gas valve thermostat is corroded/shot.
Related, I found ***Link Removed*** where the user describes a gas valve that won't shut off (overheats the tank) and the consensus seemed to be a faulty thermostat. Mine is the opposite problem, of course, but before I go making assumptions I thought I'd ask the experts here!
So, here are my questions:
1) Is there a test I can perform to confirm a faulty thermostat? Is there an ohm specification? Or should it just be 'closed' (0 ohms) when heat is needed? Is there any other recommended testing procedure?
2) If I can confirm the thermostat is faulty, does anyone have a link to a replacement part? I'd hate to replace the entire gas valve if that's the only problem.
Thanks!
Front:
Thanks!
