dougrainer
Jun 02, 2015Nomad
Old-Biscuit wrote:Chris Bryant wrote:Old-Biscuit wrote:
Can't see how 120 AC would be suspect....separate junction box, separate wiring runs etc.
I have to admit some convoluted reasoning there- simply because I have seen weirder things happen. My (flawed) thinking involves a bad ground, with enough leakage from the element to raise the water heater ground enough to backfeed through the gas valve to a ground through the module.
Theoretically, it could happen- in the real world, the water heater is grounded through the copper LP line, at least.
Wouldn't element need to be energized for that to even remotely happen :H
IF you need to replace solenoids..........HERE
AND how does Dougrainer's posts show up when not originally there and then poof there they are :H
I have mastered the art of Time Travel. Doug
