isonychia
Jun 25, 2019Explorer
Old-Biscuit wrote:
Make a soapy solution (1 TBSP dish soap/water in spray bottle)
With the propane valved in for service
Spray the propane line connection at gas valve and check for bubbles
Do NOT spray the outlet side of gas valve ...you will clog up the orifice
IF no leaks on line/fitting ...rinse with clean water
Then using a BBQ lighter see if you can ignite any propane at end of burner tube
Gas valve ----requires both solenoids to open gas valve.
One alone will not open it.
Propane system pressure is only 0.4 psi (11"WC)
12VDC is applied to gas valve solenoids for only 6-8 seconds during ignition cycle....during which time spark electrode is energized
Spark Electrode is also used in 'flame proving' circuit.......milliamp signal generated by FLAME which is detected by circuit board. No Flame signal...No DC to gas valve solenoids (easy to check with voltmeter on gas valve red/black wires)
Gas valve 'could' leak....rare but possible
Circuit Board.....could be faulty (doubt it)
If faulty it is more likely it would NOT send DC to gas valve or not send DC to spark electrode
HVAC guy sounds like a parts changer. Which eventually works if you throw enough parts at it.
Here is the wiring diagrams for 12VDC (propane) and 120VAC (element)
Maybe the HVAC guy can figure it out
Thanks for the detailed info, I really appreciate it.
I know my friend is not a novice at his HVAC trade. He runs his own business a lot of it commercial etc. for many years, He has taken care of a lot of stuff for the camp trailers and knows his stuff. Granted I know he has not spent his years servicing suburban rv water heaters.
He suggested we look at the heater more in detail this weekend. He suggested getting the board so we had it in case it was a problem.
As soon as I smelled gas, he quickly looked at the unit, then told me to shut it off.
The heater is brand new. It was working fine for the 3 weekends I have used it. I just happened to be sitting near it on Sunday and I mentioned to him I smelled propane.
I didn't think with all the safety measure in place it was even possible for the unit to fail this way. (expel gas with no flame present).
We will know more this weekend.
iso
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
