Chevyman2006's avatar
Chevyman2006
Suburban water heater not lighting
This morning, the water was not hot.
The water heater burner was not going. Turned off switch and reset. You can hear/see the igniter lighting...but burner wont light. It seems as its not getting gas.
Gas supply is full and everything else is lighting except water heater. The WH was working fine until this morning.
Any ideas?
Thanks in advance
  • Meter set to DC Volt
    One probe on terminal at solenoid
    One probe to good ground
    Turn on 'gas' switch..check voltage reading when sparking is occurring
  • Old-Biscuit wrote:
    With sparking occurring you are getting 12V DC power to unit (to/thru ON/OFF switch, to/thru both t-stats and to module) Question is are you getting power out of module to gas valve?
    Check for 12V DC power to gas solenoids (brown wire) when sparking is occurring.
    Power is sent from module to gas solenoids for 6-8 seconds during sparking attempt.....IF main flame occurs an induced signal is sent back to module via spark electrode that holds gas solenoids open.
    IF no main flame then module shuts down power.
    IF you are getting power to gas valve......is it opening (bad solenoid).
    If opening is gas flowing.....blocked orifice, burner tube
    If you are NOT getting power to gas valve.......bad ground connections or bad module
    Could you guide me through the steps of testing these connections with a multi-meter?
  • With sparking occurring you are getting 12V DC power to unit (to/thru ON/OFF switch, to/thru both t-stats and to module) Question is are you getting power out of module to gas valve?
