BB_TX
Aug 30, 2021Nomad
Your Suburban water heater most likely has a 1440 watt element meaning it pulls 12 amps. Even if it had a 1500 watt element it would only be 12.5 amps. And if someone happen to install a 2000 watt element it would be 16.7 amps.
The melted wires could have been caused by the switch overheating. But more commonly it is because of a poor wire connection; weak crimp, connector crimped on insulation, some wire strands missing from crimp, etc. Burned/melted insulation almost always occurs at a wire connection point. Poor connection equals resistance equals heat. And it doesn't take much resistance to generate enough heat to melt the wire insulation.
