dougrainer
Jan 05, 2017Nomad
Cholla Bob wrote:
I called Rheem tech and their Rheem Protech Marathon thermostat will directly replace the Suburban, has a lower hi-limit safety (150 than 180); has variable temperature control; and is way less expensive. Probably a more durable thermostat. Sounds like a good way to go.
I looked at the Rheem tstats. Unless there is a Tstat NOT listed, HOW are you going to MOUNT a Rheem where the Suburban tstat goes?????? Besides, Don't you think Suburban has a REASON they have the hi limit of 180 degrees, instead of 150????? Can you post the Rheem tstat Part Number? Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
