Cholla_Bob
Jan 05, 2017Explorer II
I drove the 60 miles and bought the Suburban 232306 thermostat. Realized the small thermostat niche had a screw in the center and that I would have to engineer to make the Rheems, Camco, or Everbilt thermostat fit. dougrainer's comment above captures the problem. As it was starting to storm here; I went with the Suburban. These other hardware store thermostats have a 170 degree limit, not 150 as I had been previously told. Also a reset and variable temp control for under ten bucks. All the single element electric hot water tanks are 120V wired to a thermostat to an electric coil with a pressure valve; basically all the same; however, the Suburban thermostat was the easiest to install, so I went with it. Thanks for all the help on this one: I have hot water again just before it started snowing.
Old-Biscuit got the problem: the coil side hot out of the thermostat burned up because the thermostat compartment insulation got wet and shorted with the tank. Important to tighten the cover screws good and I am now sealing with silicone.
PS: For ten years, the Suburban reset button has never worked once. Hope everyone else has had better luck with that.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
