j-d
Jan 06, 2017Explorer II
Congratulations! Glad you have it working. Sounds to me you did a good job finding the problem, getting the right part and up and running in one try.
I don't think anything will protect against the element burning out if we don't have enough water in the tank. What's way worse is the "standing pilot" LPG models. At least in Atwood, the high limit of the thermostat in the Gas Control is called ECO (Energy Cut Off) is a One-Time setup. Ever overheat that, like with a dry tank, and it needs an expensive new Control to get it going again.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
