Cholla_Bob's avatar
Cholla_Bob
Suburban Water Heater Thermostat Replacement
The 120V Tstat/switch electric thermostat on my 10 gallon Suburban needs to be replaced as it is confirmed blown. Is there a 130/140 degree Rheems or Camco household equivalent thermostat for a 1500 watt Camco coil? It would be great to start buying thermostats at the local hardware than driving 60 miles to get the Suburban 520788 120V switches at premium cost. Water heater is hooked up to non-mobile 120V household electric. Thanks!
  • I called Rheem tech and their Rheem Protech Marathon thermostat will directly replace the Suburban, has a lower hi-limit safety (150 than 180); has variable temperature control; and is way less expensive. Probably a more durable thermostat. Sounds like a good way to go.
  • j-d's avatar
    j-d
    Explorer II
    Went back and looked at the Amazon link and a reviewer says that one's a 150*. But the little "knob" makes me wonder if it's adjustable... The numbers OB posted are for a 130* standard and 140* optional. Decision where to go or wait for an order, might need to be based on the temp you want.
    I think it was OB, posted a pic with that solid wire connecting the two t'stats burnt through.
  • The current Suburban thermostat is black with the element wire burnt in half. No doubt this is the problem. House fuse box switch was still active - not thrown. There had been contact with a small piece of fiberglass insulation.
    Probably easiest to take the 60 mile drive today and get a new Suburban; however, I may call Rheems tech; as j-d said, this is a simple circuit. There should be a Rheems equivalent-some with variable temperature controls. I would imagine this is what cpaulsen is purchasing at Home Depot and Lowes.
    I have replaced the heating element several times now with a hardware store Camco 1500W, as our hard water seems to be the cause of element failure. Definitely the thermostat this time, but never have seen a burnt up one.
    Thanks for the help!!!
  • I have almost got my replacement thermostats from Lowes/Home Depot or Ace
  • FYI.......and future purchases (just order on-line)
    Here are the part numbers for 'standard' and 'optional' t-stats
    Suburban OEM Standard 120V AC t-stat set (normal/130*F HI/180*F) part # 232306
    Suburban OEM OPTIONAL 120V AC t-stat set (normal/140*F HI/180*F) part # 232317
    For the 12V DC
    OEM Standard (130*/180*F) part # 232282
    OEM OPTIONAL (140*/180*F) part # 232319
  • j-d's avatar
    j-d
    Explorer II
    OK... But... Are you sure? The circuit in the Suburban electric heat is pretty simple. Power on the black wire (hot) through a switch or two, that set of thermostats, the element, then back through the white wire (neutral).
    I'm a decent troubleshooter and determined our element was open. Replaced it and no go. Turned out the neutral connection was open in a junction box feeding the water heater. This exact problem has happened to others with their RV's.
    If you haven't, suggest you bypass that t'stat set WITH WATER IN THE TANK!!! and confirm that it heats. Actually, most of the components in that electric heat circuit are pretty easy to bypass for testing.
  • Thanks. I will order a backup from Amazon. I do have to get one for tomorrow. Seems like a 120V electric thermostat, other than hi-limit rating, would be fundamentally the same, unless wired for more than one electric coil or for a higher rated coil.
