DutchmenSport
Jun 15, 2017Explorer
If the breaker is tripping when you run the air conditioner, then either the breaker is NOT 20 amps, or else it's getting weak.
Another thing... if you have anything running on that same circuit in the house, lights, appliances, devices) anything in the house on that same circuit, you could easily exceed the 20 amps. Make sure absolutely everything on that circuit is turned off in the garage.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
