therink
Aug 05, 2013Explorer
69 Avion wrote:Bob/Olallawa wrote:
If you have room between the tanks to modify the piping and valves and plan on keeping the trailer....Why not make it easier for the next time? rubber type pipe coupler with bands make removal/replacement a not so bad job.
That is good advice. I would hate to see someone break a tank. Those rubber couplings are cheap and durable.
I actually bought the rubber couplings and was going to install but there was only 2 short pipe nipples between the 3" Y fitting and the valves. Not enough room to cut the nipples and install couplings on either side of the Y. I found that using the methods I described, removing and reinstalling the valves was not that difficult and certainly will be easier the next time around. The tanks are only about 16" apart leaving just enough clearance for the Y, 2 valves and flanges.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
