DV_Socal
Aug 09, 2013Explorer
So yesterday I replaced the Bristol 3" cable actuated valve on my Fuzion 362 with Valterra version. It fits without any issues. Biggest challenge was moving the drain fittings apart enough to make room for removing the old valve and inserting the new one. I followed what Steve did and also loosened the grey tank valve so I can move the entire Y drain assembly away from tank. Instead of using 2X4 pcs. of wood I end up using spreader clamps (I took some pictures and will post later). It was getting dark by the time I put everything back together, so I haven't tested if everything is working as it should i.e. no leaks etc. Will report back later.
Steve - Thanks for the tips...
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
