ScottG
Mar 07, 2018Nomad
NinerBikes wrote:ScottG wrote:
Check the tube but IIRC, it says to use mineral spirits.
You might also consider using Eternabond tape.
Sounds like that's a little more permanent. Does that work around raised surfaces above an EDM roof like flanges from sunlights and such?
really either will work fine.
EB tape does a nice job on uneven surfaces. Just make sure you follow the directions exactly and use a roller to finish it off.
The down side is it's more of a challenge to get off it you ever need to replace the skylight.
EB tape is especially nice for caulking joints that want to crack repeatedly.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
