Gdetrailer
Nov 27, 2019Explorer III
groundhogy wrote:
I have a small code scanner module where you plug it in, it wakes up and makes WiFi. You use an app on your phone to read the codes.
I have been watching repair videos and see guys with these seemingly much better code scanners.
Is there a pro level scanner that is in this small module format and if so, what do you recommend?
First question is WHY do you "need" a scanner?
If you simply want to "monitor" other things going on with your engine then a cheap OBD2 dongle and a Android phone/table can do what you seek.
However, leaving those dongles plugged in all the time sometimes CAN cause phantom malfunctions causing you trying to diagnose false errors. Not to mention many "Apps" for Android are not reliable/stabil and some are just plain junk.
Many "Apps" may not be able to reset the modules or even read all of the modules in your vehicle (like ABS and BCM).
Reality is you do not "need" a scanner unless you get the CEL/MIL light.
THAT is the time a code reader comes in real handy.
It is hard to beat real standalone OBD2 scanners, I have a Harbor Freight one I bought 8 yrs ago for $60 with a coupon can also read live data. Has saved me several thousands of Dollars that I would have spent at a dealer in repairs (I bought the scanner after a dealer scammed me out of $800 one trip for a fuel pump, then another trip for $900 for new plugs, then another trip for $500 for a new CAT and they still had not fixed the original issue!).
For the money well worth it and now is a required tool that one should have if you plan to do some work on your vehicles.
You can get HF scanners starting at $30 now days and they can reset/clear CEL/MIL codes but not read live data.
The $70 level can read live data (engine running) and $120 level adds in ABS codes and reset. $190 level adds SRS (Supplemental Restraint System which is your crash AIRBAGS).
HF OBD2 CODE READERS
I personally am considering buying a new scanner and most likely will get the one that has ABS/SRS just because every time I have taken a vehicle to a Dealer or Garage I have gotten soaked at a min of $1,000 EACH time and they didn't fix the problem and required multiple returns.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
