booty51's avatar
booty51
surburban furnace will not light
sf -35 # 963105899 in 97 allegro bus. Furnace goes thru steps but does not light. I have 12 volts to relay, temp sensor, sail switch , to circuit board. Fan runs ,But I do not smell propane out exhuast or hear igniter strike. Propane tank is full and valves from tank are open. I disconnected tubing on heater and opened isolation valve to heater and I get propane! I was about to pull heater out but discovered a plinum box on the bottom of heater and do not have clearance to pull it out. I wanted to check the ignitor as next step but I suspect it may be the board that has failed. I can get to it with out pulling the heater. Any thoughts by you heater Guru's. I left out that I have 12 volts from t stat and heater responds to settings . I also have screens on the heater intake /exhaust tubes. I did look inside tubes with a flashlight and didn't see any obstructions.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
