MSGTRETIREDCSP's avatar
Jul 09, 2013
Sureflo 5,7 Water Pump
I've got a Sureflo Extreme Series 5.7 water pump in my rig. The other morning, I noticed the pump was running, but no water faucets were on nor was any water leaking anywhere. The pump will not turn off now unless the power switch at the wall is turned off.
Any ideas on what the problem might be? This pump has not been used alot and I'm hoping I don't have to replace it as they cost $300+. I sent an email to sureflo, but have not heard back yet.
This pump has 5 diaphrams and I'm wondering if a crack or leak has occurred and it won't pressure up? If not that, then maybe the micro- processor is defective? Any ideas or experience here? Thanks
  • I have a 5.7 and one day it just kept running at a slow speed and would not shut off. looked at my pressure gauge and it read over 100 psi!. I have now gutted the "smart sensor" stuff and am using it as a transfer pump now.
  • Pauljdav wrote:
    Are you on shore power? A low battery will cause this.
    Yes, I'm on shore power.
  • I know this isn't a solution, but I'd probably go for a variable speed water pump and an accumulator tank. What that will give you is a lot quieter pump, for not too much a price premium. The accumulator tank will allow water to be used for small items without having to run the pump constantly.
  • Rather than email Shurflo, I would give them a call (I did, a lot). They are very helpful there and they understand that there can be issues with the 5.7 pumps.
    Unless a problem with your installation shows itself soon, I would pretty much count on getting a new pump. For me the symptoms were exactly as "Newblue" described: The pump just keeps idling along. For one failure I just let it keep doing that, using a power switch to control it. Evertually I started getting rust and an oily taste in my water. Yumm!
    Regarding the Revolution 4, it is not as quiet as the 5.7. On the other hand, it doesn't sound like it's about to fly apart, like each of the 5.7's did. At the point my fourth pump died, I was about to go out and buy a Jabsco pump. But the rev 4 has restored my condfidence in ShurFlo's engineering.
    mlts22--Do you mean "variable" speed? Isn't it the constant speed pumps that work well with accumulators?
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
