Anonymous
Norskeman
Jun 18, 2013Explorer
downtheroad wrote:
Norskeman,
Nice write up...just wondering why you didn't mount the unit up on the wall?
Keep an eye on that plumbing. If you get any kind of leak, it might compromise your surge protector that is directly below all those pipes.
Thanks for the heads up - drain lines and water lines in the area.
The walls around the unit are very thin wood - could have installed a 1/2 inch piece of plywood to mount it on. May make that mod later or install some kind of splash guard. That was the reason why I modified the storage compartment wall - make it easy to get to it and the water lines. You can see some of the water lines are hoses instead of "hard' lines.
I took the picture before I put the cover on the unit.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
