Pewter99 wrote:
SounGuy: Thanks, you understood what I want to accomplish. Perfect! It is EMS 30 amp.
No worries, locating your portable EMS inside your camper works fine BUT you should be aware of a couple of potential drawbacks, one fairly obvious, the other not so much. Depending on exactly where you locate your EMS inside the rig you may not be able to readily see the display and 2) the contactor inside can sometimes hum loudly enough to be heard but again that would depend on where it's located. Mine is under my sofa so I've taken steps with my current hard wire EMS to solve this ... located inside a cabinet this would be less of a concern.
