BFL13
Aug 08, 2018Explorer II
Leaving for a moment what might be going on with your set-up, how did you manage to force your WFCO to the boost mode? There is no boost button.
Here are example charging times for a similar size battery bank using chargers set at 14.6v that hold that voltage for the entire recharge time (some will drop to 13.6 half way through--not the case here)
You would never try to fully recharge the batteries from 90-100 full on generator, since it would take forever. Do that when you have shore power.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
