siggyd777
Aug 08, 2018Explorer
If the WFCO output is 14.4 VDC, then you should see about 14 Volts on the batteries!...or you have a bad connection / or an open connection if you only see 12.5 volts. Check if there is a bad fuse or solenoid in between.
Siggy
Siggy
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
