LipschitzWrath
Aug 08, 2018Explorer
beemerphile1 wrote:
If you read 14.46 at the converter but only 12.43 at the batteries, you have a wiring problem, not a converter problem.
If your retrofit LEDs flicker, that could just be cheap China product LEDs, not necessarily the converter.
I think a high resistance connection could also contribute to flickering, could it not? If only one or two lights were flickering, I'd blame the LED quality, but all of them?
I'll start with checking the connections. Best way would be to disconnect power and measure resistance across cables and connection points, correct?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
