LipschitzWrath
Aug 08, 2018Explorer
wa8yxm wrote:
Ok Two Group 31's is about 250 amp hours.. If they are at 50% (you have run them down too far) they need 2 hours at 55 amps to get close to full, 2 hours at lower amperage MINIMUM to fill up That is MINIMUM. note that 55 amps is about as big as you want to use on those batteries. Way too big for a Group 24
I normally say six hours is the minimum to fully charge.
So it sounds like the converter is working.. But just to check...
Go to the converter itself with a digital volt meter.
Voltage before you fire up ye old generator
Voltage 2 minutes after generator engages (Transfer switch transfers)
and voltage every hour after that.
Post results.
My bank is 210Ah. In the original post.
Six hours from empty to full. Okay. I'm taking 12 to go from 1/3 to 2/3.
I disagree the converter is working correctly.
I will run your test as soon as the camper gets back to the house. That said, you say measure the voltage. My question is - which voltage? The voltage at the converter output terminals? Or at the battery terminals? In my case they are not the same, which in and of itself is a problem I believe.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
