BFL13
Aug 08, 2018Explorer II
The usual arrangement is to have the converter wires to the fuse panel and fuse panel "battery" wires go to the battery. It is unlikely yours is any different, but you can check for that.
Two wires on pos battery post is normal if not more. One to fuse panel pos battery lug (fused near the battery), one for the emergency breakaway switch (not fused), and one for the slide (fused)
Two wires on the neg post can be one for going to the frame as your "ground" and another for ? ( I had two neg wires and never did find out what the second was for. It must have been to the frame too, because it didn't matter which one I used or if I used both.)
You might have done something that explains all this when you installed the new batteries. Always look at the last thing you were working on if something is wrong :(
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
