road-runner
Aug 08, 2018Explorer III
I agree that if the battery voltage is a lot lower than the converter voltage you have a wiring problem. If you could measure positive-to-positive between the converter and battery, then do the same negative-to-negative, you'd at least figure out which side of the wiring the problem is with. I also agree that WFCO converters have major reliability issues, but if the converter isn't causing the problem, replacing it won't fix the problem.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
