LipschitzWrath
Aug 08, 2018Explorer
BFL13 wrote:
The usual arrangement is to have the converter wires to the fuse panel and fuse panel "battery" wires go to the battery. It is unlikely yours is any different, but you can check for that.
Two wires on pos battery post is normal if not more. One to fuse panel pos battery lug (fused near the battery), one for the emergency breakaway switch (not fused), and one for the slide (fused)
Two wires on the neg post can be one for going to the frame as your "ground" and another for ? ( I had two neg wires and never did find out what the second was for. It must have been to the frame too, because it didn't matter which one I used or if I used both.)
You might have done something that explains all this when you installed the new batteries. Always look at the last thing you were working on if something is wrong :(
Fair point.
That said, the converter sits on a wall in a storage compartment. This wall is shared with the battery storage compartment. I cannot express to you how closely these two sit. The wires might be 28 inches long. Maybe. You can tug on the wire in one compartment and see it move in the other.
The arrangement is as I described. I'm not making this up. I don't know if this is original, but I sure as hell didn't touch it.
The dc panel on the other hand, sits 25 feet away in the living area.
It seems contrived to wire it the way you describe for this particular arrangement.
