LipschitzWrath
Aug 14, 2018Explorer
BFL13 wrote:
For this example just think converter instead of inverter, same deal here:
When I had the inverter to battery set up with an inverter that has two pos and two negs this all came up about splitting the amps. Using a two- battery bank---
If you put a pos and neg to each battery, then each battery supplies 1/2 the amps the inverter is drawing (in theory)
the same wires also act as parallel links between the two batteries, so you don't need another set of wires for that.
OR, you can put two pos and two negs across the bank per Method 2, and now you do need the parallel links. You don't have to worry if each is doing exactly half or just a little from one and a bunch from the other due to various possible reasons.
If you go with the first way, as soon as you get your Trimetric shunt in the mix, now you can't get a Method 3 situation, because the two negs now go to the shunt one end and then another fat wire goes from shunt to battery.
EDIT--the circuit breaker on the pos should be at least a 60 amper now that you will be getting full amps across it from the converter. Often that fuse or breaker is OEM undersized because they know their wiring makes it impossible to achieve full amps.
I *THINK* I understand what you are saying. I guess my follow up question is - wouldn't you want the load on each battery to be half? Maybe I'm misunderstanding, but it sounds like you're implying there are problems that go with that. I'm curious what they are.
I think that the shunt can be integrated just fine. The two negative cables (1 running to each battery) go to one end of the shunt, everything else goes to the other end. Nothing can make it to either battery without going through the shunt.
Valid point on going with the 500A shunt to future proof against an inverter install. Looks like the terminals on the 500A are 3/8" bolts so I would have to replace or drill out all the ring terminals I just put on those cables. Bummer.
In the other thread, you said those bolts are pretty short. Could you merely put longer bolts in there? I've got some serious stacks going as is.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
