MEXICOWANDERER
Aug 15, 2018Explorer
https://www.ebay.com/itm/Marine-RV-Brass-6-Gang-Terminal-Block-Connector-Common-Buss-Bar-100Amp-12V-48V/163151308012?epid=5021489698&hash=item25fc9364ec%3Ag%3AMJcAAOSwjZ5bTDcM&_sacat=0&_nkw=100+amp+buss+bar&_from=R40&rt=nc&_trksid=m570.l1313
It says 100-amp, but common sense tells me 50-amp maximum.
This would act as a great sub-branch distribution point either positive or negative. Lose the fumble screws, buy #8 stainless screws 3/16" longer then use 6x32 KEPS NUTS...
to minimize the fumble-factor when assembling. Hooking a ring terminal over a screw/stud then screwing down a nut with attached washer is light years easier than lining up a screw and terminal ring.
On busses used for positive distribution set your fuse or circuit breaker coming off the buss bar.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
