Gjac
Jan 23, 2019Explorer III
When I changed my 120 v element I noticed the same thing. I had to spray the element with PB blaster and work it back and forth with a needle nose pliers because the rust was so bad. It eventually came out and I cleaned the hole out with emery cloth before installing the new one. I believe you can remove the 12v element and install the new 120 v element in its place if you can't get the old element out but can't see how a 12v one would work off 120 volts. Do you use the 12v element?
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Aug 06, 2017
